AVG Cleaner for Fire Cube
Hi James,
We're afraid as AVG Cleaner can be used on Google Android 6.0 (Marshmallow, API 23) or higher operating systems alone.
For further queries, feel free to write back to us.
Hi, I don't have an option to install AVG Cleaner on my Amazon Cube. I can install it on my firestick but not my Cube. Is it supported? Thanks. James
Hi James,
Hello James,
AVG Cleaner was designed to use it on Android Smart phone. As you are using it on Amazon cube,  I'd request to submit your query to our AVG mobile support team along with the screenshots of it to assist you further.
Please visit the following website AVG Mobile support team (https://support.avg.com/support_contact_form?l=en&retUrl=support_Android_AVG_Antivirus), fill in your details, issue description and click on "Request Answer via Email". They will get back to you via email with a resolution at the earliest.
Hi, thanks for the speedy feedback. I found my AVG Cleaner; it was in my Apps folder (grayed out showing as another Apps Folder!). When I selected this graphic, it started AVG Cleaner by flipping from portrait to landscape. I wonder why that is?
