Hello;I`d like to help me to delete AVG from my PC,because I have Windows XP ,that do not work wit AVG.I tried to delete it,but this was immposible!
Hello,Support center,
Unfortunately, the problem persists. I can not open my medical software, when the AVG is connected, a message appears that Firebird is not on.If it is convenient to do another attempt to remote connect tomorrow.ALL PROGRAMS LOAD VERY SLOW IN 10 MINUTES
Тhank you very much
Hello Daniela,
I apologize for the inconvenience. You can reconnect to the remote session when you have a convenient time and we will continue to fix the issue.
I am sorry to hear this, Daniela.
Can you share the (screenshot) of incompatibility message that you get?
To confirm whether the issue is due to AVG or not, try disabling it temporarily.
Open AVG Internet Security interface.
Click on "Menu–>Settings–>Troubleshooting–>Passive Mode".
Slide the green cursor to turn off the protection.
Hello,dear Support center
Now,I have problemI with activating skype, after installing avg, a program incompatibility message
Hello Daniela,
