AVG Driver Updater problems
Hello Hugh,
Sorry to hear that you are unable to activate AVG Driver updater in your PC. Please install it as per the steps mentioned in this article ( http://support.avg.com/SupportArticleView?urlname=Download-Install-and-Activate-AVG-Driver-Updater ) and activate it by opening AVG Driver updater-> 'Support' tab->click on 'Enter registration key' option' and enter the registration key.
I have been trying to install the paid version of AVG Driver Updater but do not get the "Activate Now" box coming up so that I can enter the Registration Key. Any suggestions? Thank you.
Hello Hugh,
Hello Hugh,
I appreciate your efforts so far. I have sent you an email to the registered email address. Please follow the email steps to get in touch with our remote technician. They will help you to activate AVG Driver updater with free of cost.
Hello Abirami. Thank you for your response. I havd previously tried what you have suggested without any success. The box where I enter the registration key still does not appear. Can you suggest why this is please.
Kind regards, Hugh Hyghson.
Hugh,
I understand your situation, but remote connection or remote support is provided by AVG Customer Care as an alternative to standard email, chat or phone support. It is typically offered for issues that are best solved by an agent accessing your computer over the Internet. You can sit back and watch it.
If you wish to do it by yourself, please check if the activation box is appear on the right bottom of your desktop. If not please press Alt and tab simultaneouly.
If you face any difficulties, please follow the email steps to get in touch with our remote technicians.
