Hello Andy,
We apologize for the inconvenience caused. We'll check and help you out.
Please refer the below article and follow the steps as mentioned under "Define Network profiles" and under "More Enhanced Firewall settings", get into "system rules".
Once you are in system rules window, enable "windows & file printer sharing" and "allow remote connection to this computer".
(https://support.avg.com/supportarticleview?l=en&supporttype=home&urlname=use-avg-antivirus-enhanced-firewall)
Once these changes are made, check the connection status with your Smart TV.
So looking at posts on here quite a few people have had the same issue that when you disable to firewall on AVG you are able to connect to your Samsung Smart TV. I have done all the steps i could find to try and fix it
1) sharing internet connection
2) making sure i switch to a private network
3) i even tried to find out which ports and application and create firewall rules - svchost enabled talking on port 3702
but none of the above fixed my issue. Please could i have support to fix this as dont want to disable my firewall each time i want to connect to the smart TV.
Hello Andy,
