AVG has removed System Mechanic from my laptop.
When I try to re-download and install, the exe file is instantly moved to quarantine.
Regards
I have the same issue now. When I attempt to restore from quarantine, I get the message, "Whoops, error occurred. This file can't be restored." Please advise.
Hi Amos,
Thanks for posting your concern in community forum.
Is the detected file legitimate?
If yes, I request you to submit the file in the below link for analysis.
https://www.avg.com/en-ww/false-positive-file-form
After analysis, our concern team will reach to you via email.
Hi Sarath.
I'm using AVG Internet Security and, in the menu section, I do not see a virus vault. Thus, I can't find any quarantined files or programs. I tried to do as you suggested to Amos but I can't follow up. How do I find the virus vault in order to restore my quarantined System Mechanic? Thanks.
Hi Sarath.
Thank you
System mechanic is up and running
Glad to know that your issue has been sorted, Amos
You are welcome.
Hi Amos,
