AVG Installation Issue- It says Installation Error
Hi Hardik,
We regret the inconvenience caused.
In this case, we'd request you to follow the below steps & remove any/all traces of AVG from your Mac:
  1. Open 'Finder'
  2. In the menu bar, select GO > GO TO FOLDER
  3. Type: /Library/Application Support/
  4. Locate and delete AVGAntivirus folder manually (Restart your mac)
Once all traces of AVG has been removed from your Mac, please try reinstalling AVG Antivirus.
Let us know if you need further assistance.
AVG Antivirus is already installed, please uninstall the previous version first.
I have checked whole file system and couldn't find any file related to AVG, Please assista s I can't install AVG in my MAC Machine.
Thanks,
Hardik
Hi Hardik,
  1. Open 'Finder'
