Hi Andrew,
We apologize for the inconvenience caused. I request you to completely reinstall AVG using the AVG Remover tool and install it again.
1. To download the remover tool, please click on this link: http://aa-download.avg.com/filedir/util/AVG_Remover.exe
2. Select the name of the AVG Program that you want to remove.
3. Your system will be restarted and AVG will be removed.
4. After the restart, delete the AVG Remover folder from C drive.
5. Finally, install AVG Internet security using this link : http://files-download.avg.com/inst/mp/AVG_Internet_Security_742.exe
We appreciate your efforts in fixing this issue. Please do not hesitate to contact us for further assistance.
Still getting error code OxC0070643 event.exec.finished. even after following the sequence in the reply below previously.
Hi Andrew,
