AVG Int Sec FileRepMalware problems
Hi and thanks for reply.
I managed to work out what it was.
Web updater software by Air Soft, How it got on my system I do not know.
http://www.shouldiremoveit.com/Software-Updater-102250-program.aspx
Refers to it, gets installed when you instal otehr software but I am normmaly very careful when I install things, hopefully this helps others who may run into same problem.
I did have some malware software to get rid of this things and that is what found it. Once I unstalled the software and ran a virus full scan of system, problem solved.
Phil
Hi Phil,
We regret the inconvenience caused.
Could you please send the screenshot of your error messages so that we can assist further? Please click on the following link http://support.avg.com/SupportArticleView?urlname=How-to-create-a-screenshot to send the screen shot.
Hi all, quite sure this may of been asked. However.
Twice a day AVG Protection Internet Security for multi devices I recently installed keeps popping up a message about "fileRepMalware is safely in my quarantine, well obiously not as why does it keep having to tel me it is.
Rest of pop message says in…om/2web_updated_setup_1.0.42.0_1s2.exe  … files Webupdater \1.041.0\webUpdater.exe.
I have ran a full system scan and it doesn't even find it
All advice welcomed.
Phil
Hi Phil,
We appreciate your efforts. Please let us know if you still facing that same issues to assist further.
Hi Phil,
