Hello Nico,
We are sorry to hear about the inconvenience caused. You could try to unlock your mobile as described in this article http://avgclick.me/LockedPhone . If these steps does not help, we request you to contact our android mobile support team as this community deals with the technical queries regarding AVG Windows products and AVG Android support is provided through email only.
Please click on the following link ( http://avgclick.me/AVGtechnical ) and fill out your details, select as Android then the name of AVG Program that you installed in your mobile and in description please completely explain about your issue and finally click on Email option. Please select you are using a paid version even it is a free version you are using. The AVG mobile team will reply back to you via email with a resolution. Thank you.
Hello Nico,
On my android phone (JiaYu S3 - TF 5.1.1 v2.3) AVG is/ was installed.
Because of repeating requests to use AVG anti-theft I decided to activate the feature.
Doing so, I decided to deny access right for my location as well.
Getting up in the morning, I wanted to unlock my phone with my normal access code. Doing so didn't work out.
I rebooted, but again no access.
It looks like the device recognizes my four digit code, because it empties the pin-code field after the 4 digits. (It was set to start without giving an enter, after entering my 4 digit code.)
It lookes like a link with a startup script has disappeared.
Because nothing worked I decided to flash the memory by going back to another version from the OS. I used TF http://www.needrom.com/download/rom-xtreme-rom-tf/ and went back to http://www.needrom.com/download/jiayu_s3_5-1-1/ by using TWRP.
But the result is the same, so no removal of the pin code screen.
So, I have got pretty much a bricked Phone.
What can I do, how AVG help me?
Is AVG going to pay for my phone now?
