The new version of Firefox v60 is currently being disabled from connecting to any site by AVG Webshield. This needs to be corrected. I shut off Web Shield and resolved the problem.
David, please go to the below location and add the certificate manually to Firefox…
/Library/Application Support/AVGAntivirus/hub/usermodules/020_cert.sh" start and then add the certificate manually to Firefox.
Hello David,
This isn’t expected behavior. We’ll work through fixing this together.
To be sure, are you able to access all websites from other browser on Mac?
May I know the version of AVG Antivirus and Mac?
Hello David,
My apologies for delay in handling your case.
You can follow the below instruction to fix this issue:
1. Quit Firefox - quit not just close (You have to right click on the Firefox icon and select quit).
2. Open terminal app (from utilities folder) and enter: "/Library/Application Support/AVGAntivirus/hub/usermodules/020_cert.sh" start.
3. Restart MAC.
If there is any issues with with terminal command, then please share a screenshot of terminal window to assist you further.
Best regards,
Hello David,
Hello David,
3. Restart MAC.
Best regards,
When I attempt to add it to firefox throught the import certificate process, the file you have indicated is grayed out until I select every type of file. I then try to add it and it comes back and asks for a password to decrypt the file. I give my system password and it replys "Failed to decode the file. Either it is not in PKCS #12 format, has been corrupted, or the password you entered was incorrect"
AVG Version 18.2 (99c8aa549be2)
Mac Version 10.13.5 (17F66a)
Firefox Version 60.0
