AVG Management Console (AVG Zen)
Hello Kath,
Please be informed that the new AVG management console is formerly called as Zen.
To access your AVG management console, open AVG Internet Security dashboard and to the left corner of it, you can find small "HOME" icon.
Click on it to get the AVG management console opened.
Click on Secure VPN and check whether it is installed.
If it is installed and says as trial then follow the steps as mentioned in this article: http://support.avg.com/SupportArticleView?urlname=Activate-AVG-Zen-Protection-Performance-or-Ultimate to activate Secure VPN subscription.
I have sorted my problems with AVG anti-virus by using your two remove / clear tools and reinstalled my product and scanned so that is all  Hunky Dory!  But however many times you tell me I have the Zen Console, I have clicked everything from the  screen but no VPN  to activate.  You will find a screen shot of my console on my laptop as the only image in a new Folder on our  Flickr  page                    www.flickr.com/photos/tombuidhe/37728245255/in/album-72157666714430779/  Kath
I am still confused. When I open my AVG  The "Console" is called  AVG Anti-Virus (that is the image you can see on our Flickr Page,   there  other "Consoles"  that show  AVG Internet Security   - Why the difference?  Is  that the console where by I access my paid for VPN. How do I change / upgrade to show AVG Internet Security.  My husband spent two to  three hours this morning removing all traces of AVG before it would download again. And now we are back to going round in circles  with the VPN issue.
Follow the steps as mentioned in this article: http://support.avg.com/SupportArticleView?urlname=Activate-AVG-Zen-Protection-Performance-or-Ultimate to log into AVG network using AVG my account credentials.
Once it is done, click on Secure VPN tile and proceed with the installation.
If there are no trial notices displayed on Secure VPN then you can confirm that paid subscription is activated.
Thank you for providing the screenshot.
I see that you have installed AVG Antivirus 2016 version and not the latest 2017 version.
I request you to remove 2016 version using AVG removal tool as mentioned in this article: http://avgread.me/1DEtNP0 .
To download, install and activate AVG Antivirus 2017 version, please follow the steps as mentioned in this article: http://support.avg.com/SupportArticleView?urlname=Download-and-install-AVG-AntiVirus-Internet-Security-or-Premium-Security .
Once it is installed, open the dashboard of it and click on small "HOME" icon which will be on the left corner of the dashboard.
It will bring up AVG main user interface in which you can find "Secure VPN" tile.
Kath,
I understand this must be upsetting. I have sent you an email, please follow the email instructions to get in touch with the remote support. They will analyze the issue with AVG Protection and fix it with free of cost.
Kath, Also just for your info, which might prove useful in the future, the bottom RH corner of your screenshot shows 16.151.8013 i.e. the AVG version 2016.
