Hello Alexandros.
Thank you for sending the requested data. Our technical support team will analyze it and get back to you via email at the earliest. Please contact us back should you need any further assistance. Thank you.
i don't know what happend but everything seems to be ok now, i fixed it somehow…sorry for bothering you :)
Hello David,
Sorry to know that you are facing the same issue as Alex.
Yes, please go ahead in sending us the diagnostic data and once sent it will be analyzed by our level two technical team and they will reply to you only via email. Please check for the email on spam or junk folders if it is not present in the inbox. Thank you.
This is on Windows 10 Pro x64.
Hello Alexandros.
Ok thanks, I sent the info.
Hello David,
Glad to know that your issue got resolved. Please do not say as bothering, it is our duty to help our customers. We are glad that you contacted us for the issue.
I'm finished, hope it's working now…
