David, Did you totally uninstall AVG Zen?.. See Sreedevi (AVG Technologies) within posting (https://support.avg.com/answers?id=906b00000008ogtAAA).
Any update to this issue at all? I am having same issues on Windows 7.
I decided to uninstall the free version of AVG to purchase and upgrade to the Pro version. After installing, i noticed that my install is stuck on 86 percent on my Zen screen.
I have followed the instruction of running the AVG Reset Access tool and the AVG removal tool also but still no luck.
Does anyone know how to fix this as it appears to be a known issue.As im getting frustrated.
I'm running Windows 10.
Hello Justin,
Could you please let us know the AVG program you are trying to install? and also let us know whether you have received any error message while installing the program.
AVG ZEN. No error messages. Installation of 'protection' just hangs on 86% and has been stuck for over 12 hours. I have tried uninstalling AVG and re-installing but the issue still remains.
Hello David.
It is indeed disappointing when you have to contact us multiple times about the same issue but I’ll find the quickest way to get this resolved for you at the earliest. I have sent you an email regarding this issue. Please check your inbox and you would be good to go.
