AVG Rescue CD does not recognize network adapter
Greetings.  Just checking in to see if any progress was made in the last 45 days.  Is a download that includes a fix available?
Hi Darren,
Sorry for the inconvenience,
Unfortunately there is no fix.
Thank you
Thank you for your response.  I look forward to receiving an update once the concerned department has completed their analysis.
Hi Darren, thank you for providing the detailed information. We have escalated this issue to the concerned department and they are working on this issue. I request you to check this thread very often for a solution. I appreciate your patience and efforts. Thanks.
Hi Darren,
Thank you
