See topic title.
Tried reinstalling and everyting else, at least twice.
Whenever I switch on the VPN, the wireless card is turned off. My Win10 control panel finds a "secure vpn" wireless card that gets disabled every time the actual wifi card is turned on, and vice versa.
The laptop is a 2015 HP Probook 450 G2, the system reqs are met anyway,
Tried all the settings except the experimental ones, nothing works..
I have AVG Internet security so there should be no conflicts, anyways I tried disabling it but it doesn't change a thing-.
Using a LAN cable is not an option at the moment, but in any case I won't settle for it - the VPN has to work on ALL wireless connections otherwise I'll cancel the subscription.
Any help is appreciated
