AVG Tune Up won't remove system junk
Hello Graham,
Let's work together to fix it. Please try repair installation https://support.avg.com/SupportArticleView?urlname=Repair-AVG-Antivirus and check if that helps.
You can share the screenshot of that page if the issue persists.
Hello Graham,
It used to. Has something changed? Does it rely on a built-in Windows 10 utility that no longer exists ? It hangs on 87% removal and tells me to wait a few minutes. After 2 hours, I figure there's a problem… anyone know what it can be?
