AVG Ultimate firewall problem
Hello Hans,
I can understand that you are facing issues with your printer after installing AVG Ultimate. First of all, I would like to appreciate all the troubleshooting that you have done so far.
We request you to check if File and Printer Sharing is enabled in AVG Firewall . You can refer this article: http://support.avg.com/SupportArticleView?urlname=How-to-enable-file-sharing-or-printing-with-AVG-Firewall. If the file, printer sharing is disabled, it will block the printer sharing. If issue persists, kindly provide us a screenshot of AVG Firewall component so that we can help you better. Thank you. Komal, AVG Customer Care.
Hello, all is working fine except printing via Netgear USB Control Center.
The printer is connected to the USB port of the Netgear WNDR4500 router and works fine from 3 other computers but after installing AVG Ultimate on my W10 laptop it fails to connect.
I already tried to open a UDP Port as it is configured on one of the other computers but no succes.
When I switch off the firewall the printer appears in the Netgear USB Control Center window but ass soon as the firewall is on the window is empty again.
Is there someone who can help me fix this?
Thank you fore your answer.
File and printer sharing is enabeled. It was one of the first things I checked.
Is it possible to change the language because it is now all in Dutch.
I can imagine it will not be as claer for you as in English.
User-added image
Hello Hans,
Thank you for your valuable efforts. We would request you to know whether you have installed any other AVG Program before in your system as Dutch language? Thank you.
Hello Hans,
We certainly understand your concern. We have sent you an email instruction to get connected with our technical support team. Please follow those instructions to get in touch with them and you should be able to resolve your issue. Thank you.
Hello Hans,
Hello,
Problem is solved,
In the white list IP numbers added 192.168.1.1 and it works.
Thanks for the great support.
Kindest regards,
Hans
