Hi Asok,
From your description, we're uncertain if you've successfully reinstalled AVG. Please let us know if you've reinstalled.
Sometimes, there might be network interruptions during the installation process, which might delay the process.
I am using AVG for last 10 years , Last year i am seen AVG is using high memory. So i re installed and solved the issue. Now same problem seen again. But this time re in stallion not worked. After downloading the software it takes a long time to re installation also. It seems AVG inter security also affected with virus.
Hi Asok,
