Thank you for the clarification, Allen.
I assure you that, the issues with AVG scheduled scan will no longer appear, if you are using the latest version.
If the issue appears, please (repair) AVG Internet Security program and setup the schedule scan again.
Allen, thank you for trying repair.
I request you to provide the (screenshot) of AVG Internet Security interface and the update window to assist further.
It still will not start up automatic. I have changed times for it to start that did not work. I think it is on your end like I said it happen once before when yall did an update it took a while for you to fix it at the time it happen I wasn't the only one that it happen to.
I have done the repair 5 or 6 imes an done it yesterday did not help I quess I will wait till I renew around
june maybe that will fix it because all yall can tell me to do is repair and it done work I need somebody that can fix it.
Hello Allen,
It shouldn't happen. Please repair AVG Internet security http://support.avg.com/SupportArticleView?urlname=How-to-repair-AVG from the control panel, restart your PC and then check the status.
I did the repair an checked this morning at 9am to see if started automatic it did not repair did not work
When AVG did there last up date my automatic virus start up 9am will not start have to do it manual. The same think happen back last year it took yall forever to fix it are you working on to fixing it?
I am sorry to hear that the issue persists.
I have asked to run repair to check if recent update have fixed the issue.
As the issue persists, I have sent you an email to get connected with our remote support.
Please follow the steps from the email and the concerned team will make sure this scheduled scan issue is resolved.
I have been having to run the virus scan manual for around the last 3 weeks it was after one of the up dates. I had this proable sometime back last year i wasn't the only one that had the proable in an answer that one of the techs wrote was they are working on the proable it got fixed a few days after that. Will check the scan in the morning
I hope this is what you need
Please run AVG repair avgclick.me/RepairAVG from your computer control panel and check if that fix the issue.
Yes, Thank you for the screenshot.
It seems that your virus and program definitions are up to date.
Do you mean that, AVG schedule scan isn't starting up after an update?
