AVG will not start
Well, I got the problem fixed by downloading and reinstalling AVG. AVG and the VPN function again as before. Thank you for you time.
Hi Thomas,
Sometimes, this might happen if there is an attempt of overriding the existing files.
As we're uncertain about the exact AVG programs with which you're experiencing this issue, would you be so kind to clarify it for us?
When I try to start AVG or AVG VPN, a pop up appears saying that it failed to start due to side by side configuration is incorrect. How can I correct this?
We're so glad to hear that and we appreciate your efforts, Thomas.
Hi Thomas,
