AVG Zen Using all CPU speed
Am running Windows 10, AVG Zen.  With all components turned on, as default, and no other applications running. The CPU has been running 85-95% dragging down all other applications.  Even with all default features turned off, CPU is running 25-40%.  Seems like the Wathdog Service is the worst offended.  Also, Win 10 is a 64bit OS, AVG Zen says it running on 32bit?
Hello Dave,
We regret to hear about the inconvenience caused, AVG Zen process is only 32 bit and it is not related with the System type. We suggest you to repair AVG Internet Security - Unlimited and check the CPU usage. Please follow the below instructions to repair AVG :
Go to Start -> Control Panel.
Select "AVG Protection"  in the list of programs.
Select Repair.
Restart your computer.
Hope it helps. Please, feel free to let us know if you require any further assistance.
