Avoid Antivirus AVG using too much CPU to check a Python script
I am currently developing a Python script that performs some http requests and uses a webdriver. When I run the script from Pycharm, AVG starts performing some sort of scanning that reduces the performance of my PC, using more CPU than the script itself.
What type of exclusion should I insert inside of AVG in order to let everything launched throught Pycharm to be excluded from scanning?
I already tried putting the whole PycharmProject folder in the AVG exclusion, but that didn't work
With AVG full disabled the problem is not present. I have also the following exceptions, but they seems not working: C:\Program Files\Jetbrains\ (Pycharm folder), C:\Python310, C:\Users\me\AppData\Local\Programs\Python, C:\Users\me\PycharmProjects,
Hi Alessandro,
We regret the inconvenience this has caused you. We'll further look into this & help you.
Let's temporarily disable the individual shields/components of your AVG Antivirus Free & narrow down the shield/component that's causing this issue.
Refer to this article to temporarily disable the individual shields/components of your AVG Antivirus Free.
Keep us updated.
We're sorry for the inconvenience this has caused you, Alessandro.
To further investigate this issue & help you resolve it, we've sent you an email with detailed instructions to contact our additional support.
Please check your inbox/spam folders to find the email and use it to get back to us.
User-added image
With file protection and behavior protection disabled the problem is still present
Good afternoon,
during the session with your expert I couldn't upload the file generated using AVG Sysinfo.
User-added image
The file size is more than 3GB; how can I send it to you?
Hi Alessandro,
Keep us updated.
