Hello Christine,
We are sorry if you feel like that way. If you do not want to receive promotional pop-up for other AVG programs, you can disable it in AVG privacy settings.
You can refer the following link to manage AVG pop-ups (https://support.avg.com/SupportArticleView?urlname=AVG-Privacy-settings). Also, you want to remove AVG Battery saver from the PC. Refer the following link to uninstall AVG Battery saver (https://support.avg.com/SupportArticleView?urlname=Uninstall-AVG-Battery-Saver). Thank you.
Hello Christine,
I canceled my battery saver subscription because I noticed that it darkens the screen and it shows my battery is running out over a shorter period of time whereas I have been using my laptop the same in the past 7 months (I am an online teacher )
I think your protection method is very invasive and I am starting to believe that you push customers to buy your products all the time using all kinds of ways to make them believe they need them. It's much too pervasive and honestly I am thinking of canceling the whole plan with you.I have been with you for 5 years but now I am feeling too much pressure from you.
Can you tell me how I can remove the battery saver from my computer? I don't want to use it anymore!
Thank you
C>Poquet
