BSOD when using OFFICE/EXCEL 2019 PRO PLUS?
Good morning,
I have already had 6 AVG experts assist me, but they do not solve anything. They all do the same:
- Uninstall AVG
- Check WORD no longer generates BSOD
- Install AVG again
- Verification that WORD generates BSOD
Uninstal and install is not a solution. If AVG does not change anything in your antivirus, everything will remain the same.
I can't be wasting time for several hours every day.
AVG must change antivirus so that this does not occur.
In a short time I have to renew AVG. If AVG does not give me a solution, I will use another brand.
As you will understand, I cannot be with my laptop restarting constantly.
Regards
Hi
Excuse me for my limited English.
I have a HP EliteBook 840R G4 laptop with WIN10 21H2 perfectly updated, both in software and HP drivers. Also, I have AVG Internet Security. I recently installed OFFICE 2019 PRO PLUS and every time I open WORD or EXCEL, after a variable time, less than 5 minutes, I get a blue BSOD screen and the laptop hangs and resets
IMPORTANT: Only BSOD when I open WORD or EXCEL. With all other app, no crashes.
I have passed the WINDOWS RAM TEST two times and it has not detected anything wrong.
What I can do ?
Thank you
Good morning,
- Uninstall AVG
- Install AVG again
Regards
Hello M P,
Thank you for contacting AVG support community.
Sorry for the trouble caused.
Could you please confirm on how long you are facing this issue?
We will certainly help you out.
Yesterday, I had 2 remote customer service sessions with 2 AVG experts.
The second expert gave me an reference number, because he escaled the issue.
Where could I see this chat or the case number ??
Many thanks
Hello M P,
Thank you for writing back to us, M P.
You can contact our AVG free remote support team at your convenient time and we are working 24/7.
We understand your concern.
If you suspect that your AVG Internet Security program could be causing this issue, please temporarily disable it as mentioned in this article & check if the issue resurfaces.
Also, please awaken any/all programs you might've put to sleep using AVG TuneUp.
Keep monitoring the situation & let us know if the issue is resolved after performing the above actions. However, if the issue still persists after disabling AVG, please be informed that this issue is not being caused by AVG.
Hello Samuel,
First, many thanks for help me.
I installed OFFICE in February 2022, but this a laptop only used in holidays. Short tests in February after installation was OK. I saw this issue just in August. Also I have updated OFFICE 2 times, but same problem. I have seen in the internet that many user have same problem.
Best regards
