Cabinet Vision 10 Blocked by AVG
I can only open Cabinet Vision by turning off my AVG virus protection, any suggestions
Hello John,
I understand the inconvenience caused, let's work together to fix this issue. I request you to change AVG Firewall network profile to private (open AVG Internet Security > menu > settings > components > firewall > customize > network profile > change all the network public to private) at first, please go to Firewall customize settings again > scroll down > click on system rules > enable all the system rules if it's not configured, please click OK and check if you can access Cabinet Vision 10 with enabled AVG Internet Security.
Best regards,
Hello John,
Best regards,
