Can no longer connect MS Edge
Hi Mike,
We are sorry to hear this.
Please share us the screenshot of the error message which you receive.
Try to reset the browser and check for the issue again.
I keep getting a message when trying to access any website using MS Edge or IE. This just started today. This is the message I receive… "
Details
Your PC doesn’t trust this website’s security certificate.
		<p>Error Code: DLG_FLAGS_INVALID_CA</p>
		<p>Because this site uses HTTP Strict Transport Security, you can’t continue to this site at this time.</p>
		</td></tr></tbody></table>
This happens for sites that I have used for years such as Microsoft's home page or my employer's home page, which I need to access my payroll data. Chrome and Firefox work fine. Does anyone have a suggestion?
I appreciate your efforts, Mike.
Let's disable AVG Internet Security on your PC and please check if you are able to access the websites.
Click on the link (https://support.avg.com/SupportArticleView?urlname=Disable-AVG-Antivirus) to refer how to disable AVG.
Yes, it is evident from the screenshot that your computer is protected by AVG Internet Security.
If you happen to see the issue with Edge browser again, do contact us immediately.
Hi Mike,
Santosh,
Thank you for your prompt response. The initial inquiry contains a copy & paste of the screen, do you still need a screenshot?
I have repaired and reset the browser several times and it has not helped.  I welcome your suggestions,  thank you.
Thank you for your help.
It appears to be protected.
User-added image
Glad to hear that, MIke.
Could you check whether your AVG Internet Security program says as "you are fully protected"?
You are most welcome, Mike.
Have a nice day!
