Thanks for your reply and offer. For some unknown reason the problem seems to have resolved itself so I no longer require assistance.
Hello Peter,
Let's have a look into this together.
Please disable AVG temporarily as mentioned here and try connecting to host server.
I am using CoreFTP to connect to a host server but am having problems doing so. I have also tried using FileZilla but with the same result. It may be a problem with the host server, but I would like to eliminate AVG first. I am using 19.8.3108 (build 19.8.4793.544). Is it possible that AVG is blocking access for some reason?
Our pleasure, Peter. Glad to know that the issue has been fixed by itself. Thank you for updating the status. Have a great day!
Hello Peter,
