Could not finish autmatic state repair
I have downloaded AVG on windows 10, and it will  not scan my computer nor will it update, stating it could not finish automatic state repair and connection is offline, tells me to go to website to fix issue but when I click on link it/states there is nothing to be done to fix issue, what is going on? Do I need to go with another company?
Hello Stevie,
Sorry for the inconvenience caused. I request you to try using our AVG remover tool once and then try installing the program.
1) First step is to use AVG Remover tool and uninstall your AVG program completely. To download AVG Remover Tool please click on the following link:
  1. Your computer will be restarted automatically. After the restart, AVG Remover will finish the uninstallation.
    If you are trying to install the AVG free antivirus program then please use this link:
    For 32 bit: http://files-download.avg.com/inst/mp/AVG_Antivirus_Free_x86_694.exe
    For 64 bit: http://files-download.avg.com/inst/mp/AVG_Antivirus_Free_x64_693.exe
