CPU Usage - Still a problem
Hello Mike,
We are really sorry to know that you are still facing high CPU usage issue with AVG Internet Security application even after reinstalling the application. I apologize for the inconvenience caused to you.
To fix this issue, we request you to get connected with our additional support. An email instruction has been sent which will help you to get connected with remote support.
If the email is not found in inbox do check on spam and junk folders. Please check for the email and connect back to us as soon as possible.
Hello Mike,
Hi:  My CPU usage was at 75% with the "AVG Service" process.  I deleted, then re-installed AVG per your instructions and the problem went away for 1-2 days.  Now CPU is at a constant 35% with the "AVG Service" process.  Please tell me you have a proper fix for this.  Mike
