Does AVG block setting up imap?
Hi Stephen,
Let us check that.
Kindly disable the AVG Protection and check if IMAP works or not.
You can refer this article for the steps to disable :
https://support.avg.com/SupportArticleView?urlname=Disable-AVG-Antivirus
Keep us posted.
Trying to set up imap with my yahoo.com and Outlook can't auto set it up.  Is it AVG Free?
Hi Stephen,
Let us check that.
Keep us posted.
