Driver for "Unrecognized device" is not working properly
Dirk, we request you to follow the repair instructions for AVG PC TuneUp program, but not for AVG Driver Updater and AVG Secure VPN.
This message should not be displayed.
To analyse this error further, we need to collect error logs from your computer.
I have sent you an email with the steps to collect error logs. Please follow the steps from the email and send me the log files.
Our senior team will analyse the logs and contact you via email with a solution.
Hello Genard,
That’s certainly not how we want your AVG to work. Please repair AVG PC TuneUp http://support.avg.com/SupportArticleView?urlname=How-to-repair-AVG from the control panel and then check the status.
If the issue persists, please provide the screenshot [ http://support.avg.com/SupportArticleView?urlname=How-to-create-a-screenshot ] of the Fix problems page to check and assist further.
Only some days ago I called AVG Helpdesk and my AGV products were tuned by remote acces,
and that seemed fine.
However, when I run AVG TuneUp, the tab "Fix Problems" indicates "1 problem found".
As suggested I use AVG Driver Updater as a message says:
"The driver for "Unrecognized device" is not working properly".
Then I run a scan, but "No updates found".
Next I run AVG Disk Doctor on both drives (C:) and (D:) but after the check,
AVG TuneUp is still indicating there is 1 problem.
screenshot 03
Hello, thank you for the support.
I repaired both AVG PC TuneUp and AVG Internet Security
Restarted the pc and ran AVG Driver Updater, but still there is that message : "The driver for "Unrecognized device" is not working properly". ... There is an option to ignore the problem, perhaps I should simply ignore?
Dirk, If applicable… For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Hello Genard,
