Epson printer not connecting after installing AVG
Avinash, thank you for the offer. However I need to check with the people I work for as I think they would not be happy for my PC to be accessed remotely. I think it’s more likely they will want me to uninstall all AVG and use another system. So I may need to apply for a Refund.
Dorothy,
Sorry for the trouble. I see that you have purchased AVG Tuneup unlimited product not Antivirus feature. Have you installed AVG Antivirus free version?
I request you to open PC Tuneup -> Speed up (Second components) -> Disable startup programs -> change Printer status from sleep mode and check with the issue. We are here if you need further help. Thank you!
Two days ago Ion recommendation, I installed AVG and now my Epson Printer will not connect. Why?
It was working fine with the previous Anti-Virus Protection.
Sure, take your time, Dorothy.
We are available 24/7.
Hello Dorothy,
Try the steps provided by Ranjani and if Printer software is not listed in PC TuneUp "Disabled programs", let us know whether you have installed AVG Internet Security trial version.
Dorothy,
I'm sorry to hear that.
Let us try a few other steps and check if that fixes the issue.
I suggest you to Revert the Changes made by AVG PC TuneUp and check if that fixes the issue. Here is an article with the steps: http://support.avg.com/SupportArticleView?urlname=How-to-revert-changes-done-by-PC-TuneUp
Also, please provide me a screenshot of the AVG Anti Virus User Interface. Here is a link with the steps to create a screenshot: http://avgclick.me/getscreenshot . You can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
If you still wish to get a Refund, please let me know and I'll help you with it.
Thanks for your reply.
Yes I have AVG Antivirue Free version and also AVG Tuneup.
I will try what you recommend and hope that works.
Akash, thankyou for your prompt reply.
I will have to try this later in the day as I’m busy elsewhere at present. As said above, Mozilla is behaving so erratically now that your suggestion could take some time!
I will reply again later.
Dorothy,
I apologize to hear about the inconvenience this may have caused. I have sent you an email instruction to get connected with our technical support team. Please follow those instructions to get in touch with them and you should be able to resolve your issue.
