Error Messgae Help
Hi Hosking,
We will help you to resolve this issue. AVG Antivirus program will work on windows platforms starting from XP SP3 and higher.
Please share us the screenshot of the error message to check and assist you further.
Thanks,
Vishnu Vardan
Anyone have any ideas why I am getting the following error message ?
C:\programfiles\AVG\Av\avgsysa.dll is either not designed to run on Windows or it contains an error.
A G M, For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Hi Hosking,
Thanks,
Vishnu Vardan
