Excessive Battery Drain
Hi Stephen,
Sorry to hear about the situation.
Please follow the steps below to reset the app and check if that resolves the issue: Device Menu -> Settings -> Apps/Application Management -> AVG Anti Virus -> Tap on clear cache & Clear data -> Force stop the app once.
Now restart your device once and check if you're facing the same issue again.
Hi Stephen,
AVG app (AVG Pro for android) using 45% of battery and excessive CPU , causing phone to overheat .
Latest version installed but makes phone unusable as lasting 4 hours instead of a day!
