Hello Cesar, I apologize for the inconvenience caused. Please have a look at this article and repair your AVG - http://avgread.me/1FurPqK .
Hello Cesar,
I apologize for the inconvenience you experienced in this case. I request you to please completely uninstall your AVG Internet Security using AVG remover tool and reinstall it.
To uninstall please follow the below steps:
1. Please click on the link http://download.avg.com/filedir/util/AVG_Remover.exe to download the AVG Remover tool.
2.Run the downloaded tool and follow the instructions displayed on your screen.
3.Your computer will be restarted automatically. After the restart, AVG Remover will finish the uninstallation.
To reinstall please refer the article http://support.avg.com/SupportArticleView?urlname=How-to-download-and-install-AVG .
Please feel free to get back to us for any issues with AVG. Thank you.
Hello Cesar. I apologize for the inconvenience caused. I would request you to try this AVG Remover tool instructions once. Please follow the below mentioned instructions:
1) First step is to use AVG Remover tool and uninstall your AVG program completely. To download AVG Remover Tool please click on the following link:For 32-bit: http://download.avg.com/filedir/util/support/avg_remover_stf_x86_2015_5501.exe
For 64-bit: http://download.avg.com/filedir/util/support/avg_remover_stf_x64_2015_5501.exe
2) Run the downloaded tool and follow the instructions displayed on your screen.(1/2)
Hi Guys
I installed the AVG internet security 2015 solution, all modules are working fine except firewall, I already tried to restore defaults settings and I followed the article "Firewall is inactive, not working or in error state" but still is down.
Can you help me please?
Hello Cesar,
To download, install and activate AVG Internet Security program please follow the instructions mentioned in the following article: http://bit.ly/1DXPL5z . If the issue persists please do let us know. Thank you. (2/2)
