Fixing problems on pc
Mary, What Windows OS has been installed on your system?.
it advises me to disable  of Administrative Shares
I bought my computor at KPM which is a computor place and they put the windows on my laptop
It says if I disable of the Administrative shares that all of previous versions will no longer function or
be available. so wouldn't that mean my laptop will no longer work?
Thank you for the information, This issue seems to be with Windows OS so we request you to get the assistance from Microsoft using this link: https://support.microsoft.com/ .
