I did a deep scan and it found this:
MacOS:AMC-AJ [PUP] private>var>db>uuidtext>08> 3289636CCD32C88D4C67EC0D571FAF
But it couldn't remove or fix it. Any advice. See photo.
Justin,
We’d like to know more about what’s happening with your AVG. Provide us your MAC OS version http://https//support.apple.com/en-us/HT201260 and AVG version.
To find out the version you can follow user manual, part 4.3. Menu in the task bar
http://files-download.avg.com/doc/AVG_AntiVirus_for_Mac/avg_avm_uma_en_ltst_03.pdf
Could you share screenshot https://support.apple.com/en-us/HT201361 of that detected message to check and assist you further?
Justin, For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Justin,
