How do I disable AVG products from startup
Hello Eric,
Thank you for reaching AVG Community Support.
We regret the inconvenience you had with disabling AVG from start up. We will certainly help you with the issue.
Please follow the below instructions to disable AVG at startup:
Open Task manager & click on 'More details' to view all the running processes > Open the 'Startup' tab> Select the AVG program and then click the "Disable" button to remove it from startup.
However, we'd like to exercise caution, as disabling AVG from startup will leave your computer vulnerable to malware, threats that may attack you device at the time of startup.
Let us know if you have further queries.
I purchases AVG ultimate but I have a slow machine and I would like to not have all these AVG processes load at start up and be able to choose when I would like to use the software. In my Task Manager startup tab I seem to be locked out from Changi g the status of AVG products. This behavior itself seems very virus/malware like which makes me question the entire line of software…
I'm running window 10 current version with all available updates loaded as of today
AVG internet security version 24.2
Edition Windows 10 Home
Version 22H2
Installed on ‎9/‎9/‎2023
OS build 19045.4170
Experience Windows Feature Experience Pack 1000.19054.1000.0
hello Shanmugapriya Samidurai
same problem here.;;
in french : je paie un abonnement annuel et je suis globalement comptant sauf pour le temps d'ouverture de mon ordinateur, largement allongée à cause de l'activation automatique d'AVG au démarrage. La méthode que vous suggérez ne fonctionne pas (disable button to remove it from startup). Toutes les autres applications peuvent être désactivées mais pas AVG
Hello Mariano,
To proceed further, please create a separate AVG community post by clicking the link below and post your questions in your own post, so we will check with your AVG account and help you accordingly.
Thank you for your understanding
Hello Eric,
