Hi Sergey,
We are sorry to hear this.
Please accept our apologies for the inconvenience caused.
We request you to follow the below steps to reset the AVG Internet Security settings to default:
Please open AVG Internet Security program installed on your computer.
1. Click on "Menu"-> "Settings".
2. Select "Troubleshooting" in the left pane.
3. Scroll down to the "Reset All Settings" section and click the "Reset To Default" option.
After following the above steps, please restart your PC and check the AVG Internet Security firewall component.
Keep us posted.
I received a notification about updating the antivirus program, followed by a restart of the computer. After restarting the computer and turning on the antivirus program, I saw the message “Enhanced firewall is disabled” (screenshot 01). In the settings in the "Full Protection" section of the "Advanced Firewall" section, it is not possible to apply the settings and check the box (check box) (screenshot 02). anti-virus version (screenshot 03). HOW to fix a firewall problem?
We appreciate your efforts.
We are glad to know that the issue has been resolved.
Thanks. The problem is resolved.
Hi Sergey,
Keep us posted.
