Hello Rob,
We regret for the inconvenience caused. Please try to follow the instructions on the article http://support.avg.com/SupportArticleView?urlname=General-Error-when-updating-AVG and check if it helps.
Hi Kishore
Thank you for your fast reply, I have followed the guide, but unfortunately it still gives me an error message, I have saved the log if you maybe want it. Is there something else I can try?
Thank you ![]()
Hi
I keep getting an error "update failed general error" and as soon as I open AVG it gives me an error code: 0xc00706bb
Can someone please help me?
Thank you!
Hi Kishore
Thank you ![]()
OK Rob, No probs… Pleased to see that you appear to be now sorted. Thanks for returning to the Community & posting.
Thanks Kishore! They have fixed it! ![]()
Thank you for your reply Ranjani
I have done everything you said step by step, but the installation reaches 21% (As it did before) and still gives me an error code. Now I have a BIG problem, I don't have any antivirus software installed at all. This is urgent now.
Please help!
Hello Rob,
Thank you for your reply Ranjani. I have done everything you said step by step, but unfortunatley it didn't work. It failed to install again. This is a BIG problem, because now I don't have any antivirus software installed at all! Please help me.
Thank you
