Ie explorer opens a blank screen then goes away after i ran a defrag
Hello Joseph,
The AVG PC TuneUp issues is might be because of corrupted/missing AVG PC TuneUp files. However, I have escalated your case to our senior team, we will contact you once we receive a reply or in need of more information.
Best regards,
Please see the attached file for the error I get when trying to run pc TuneUP.
I tried using a malware detector from another vendor and they quarantined 25 items that AVG was supposed to detect and stop but didn’t.
I quarantined the 25 items and IE 11 worked after a reboot.
SO now why am I getting this error?Error when I tried to run tuneup
Hello Joseph,
I'm sorry for delay in responding to you. We have received a reply from our senior team and they have suggested to reinstall AVG PC TuneUp. Please go to control panel > program and features and uninstall AVG PC TuneUp. After that, please follow the instruction (http://support.avg.com/SupportArticleView?urlname=Download-and-install-AVG-Performance) to download/install/activate AVG PC TuneUp. Regarding the threat not detected, we need sample/screenshot of the threat which was detected by third party to check/analyze with the threat, then we will able to find why that threats was not detected by AVG. You can check the following link to see the instructions about taking the screenshot (http://support.avg.com/SupportArticleView?urlname=How-to-create-a-screenshot).
Best regards,
I did a defrag on my disk and unexpectedly when I went to run IE explorer 11 on widows 7 professional it opened and after a few seconds disappeared. I looked up the problem on the web and it said it was likely caused by adware?. A little help please.
Hello Joseph,
I'm sorry to hear about this. You might have click Sleep/disabled in AVG PC TuneUp for IE, in this case please open PC TuneUp > rescue center > undo > restore the disabled AVG application. Please reboot your computer once and check if your IE is working fine.
Best regards,
