I have several computers that print to the same printer connected to main computer (named it "AA")
When I try to connect to the printer from one of them, called "XX" (Windows 10 all of them) I got the Incoming Connection Blocked, "We've safely blocked an attempt to connect to your computer using File and Printer Sharing". Detected by "Remote Access Field".
No other computer has the same problem.
Also the computer in question "XX", cannot see the main computer "AA" on the File Manager.
AVG Internet Security on "AA" is 22.2.3223 (build 22.2.7013.717)
Enhanced Firewall under Basic Protection has "Allow Internet Connection Sharing mode" checked.
Hello Claudio,
We apologize for the inconvenience. We'll certainly check & help you sort this.
Firstly, please share us a screenshot of the threat message you received from AVG, so that we can check & help you further.
Note: Kindly click on "See Details" on the threat pop-up and then share us the screenshot.
Secondly, if your printer's IP address is being detected by the AVG Remote access shield, please add that IP address to the AVG Remote access shield's trusted connections & check if the issue persists.
Refer to this article for detailed instructions to add that IP address to the AVG Remote access shield's trusted connections.
Keep us updated.
Hello Claudio,
Keep us updated.
