Incoming connection blocked
AVG is blocking my Media player on my local network, hence no access to my local media. I've even diabled the enhanced firewall but still it blocks. I've been using HaneWin NFS server for many years but I do not know what changed now.
I've a screenshot
Hello Busul.
We apologize for the inconvenience caused to you.
We certainly check and help you.
Do you get any error messages while accessing the media player?
If so please help us with a screenshot of the error to check and help you further.
Here is the link which has the steps to take a screenshot :
| AVG (https://support.avg.com/SupportArticleView?l=en&urlName=AVG-Create-screenshot&q=How+to+create+a+screenshot&supportType=home)
Hello Busul.
Thank you for sharing us the screenshots, Busul.
Upon checking it, we see that the Remote access shield has blocked the connection.
Samba (SMB) allows a remote connection to share files in a network. When Samba protection is enabled, Remote Access Shield monitors SMB connections to block any threats.
Please clarify whether the IP address listed in AVG notification belongs to the network media player.
If so, you can add it to trusted connection as mentioned in this article & let us know if it helps.
error screenshots
