Installation AVG using window 10
Hi, while trying to install AVG Security 2015 I occured the follow message:-
Your app doesn't work with Windows 10
The app you're trying to use was blocked from opening because it might damage your PC or result in loss of data. This is because some apps that worked with a previous version of Windows might not work in the same way with Windows 10.
Go to the support website for the app developer, and check if a new or updated version of this app is available for Windows 10.
Hello Henry. Please download the AVG Remover tool(mentioned below) corresponding to your bit version. It will remove the remnants of the previously installed AVG Internet Security and resets the registry entries. After running the tool, please click on http://avgread.me/1CrwKsb to download the latest installation file. Please run the installer and proceed with the onscreen instructions. You will be able to install the AVG Internet Security 2015 in your Windows 10. Please let us know if you need further help. Thanks.
AVG Remover for 32-bit version: http://avgread.me/ZR1SiG
AVG Remover for 64-bit version: http://avgread.me/1uLSWXs
Note: You will be asked during the removal procedure to restart your computer. Therefore, please make sure to finish your work and save all important data prior to launching AVG Remover.
I do not have AVG with my system initially before and after converting to window 10 but now I want to install AVG Security using window 10. How to I do it?
Hello Henry. Glad to know that you have chosen AVG as your antivirus software. Please check the link http://www.avg.com/us-en/home-small-office-security to know the list of products available to download. Thank you. Kishore, AVG Customer Care.
