Installation problem
Hello Kishan,
Are you trying to install the trial or paid version of AVG Internet security program?
What is the exact error code that you are receiving for the installation?
Please provide the screenshot of the error code that you received so that we can assist you better.
If you aren't sure on how to take a screenshot please follow the instructions mentioned in this link: http://avgread.me/1aZxsAV and attach the image to this post.
Just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
sir, I'm unable to install the avg total security programme
it's showing some error.
kindly help me to slove the solution.
Hello Kishan,
