Hello Sarah,
We regret for the inconvenience caused. Please check whether you have installed any other conflicting applications like McAfee, Avast, Norton etc… on your PC, If so please uninstall the conflicting applications.
If not, please click this link http://aa-download.avg.com/filedir/util/AVG_Remover.exe to download and run the AVG Remover tool to remove all the traces of the AVG.
- Having problems downloading AVG Protection. This error code keeps coming up 00xe1f921
Hello Sarah,
Sarah, If applicable… For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
