I just bought the internet security few minutes ago, but I can't install it.
It showes error message Oxe0060006.
Now Im totally exposed to all types of attackes.
Helllllllllllllllllllllllllpppppppppppppppppppp
Hi Martin,
0xE0060006 - internet connection unavailable during installation. Presuming that you have internet connectivity since that you were able to post here (not unless if you have used a different computer),
I would suggest you open command prompt
For windows 7 and below:
Click on the start (windows) icon on the lower left hand side, then just above it, type "CMD", you will see the result on the top, right click on it and choose run as administrator.
For windows 8, 8.1 and 10:
Hold windows key on your keyboard and press X, a menu should come up and choose command prompt admin.
once the CMD admin is up, type netsh winsock reset then restart your computer.
Try to install again your AVG
Hello Martin,
May I know the operating system that installed on your PC?
Do you have any other third party antivirus program installed on your PC?
Martin, Also have a look @ this official AVG article (http://avgclick.me/0xE0060006).
