Installing problem
Hello Tersia,
We will help you with this.
May I ask for which AVG program installation you are getting this error?
Could you share the screenshot of the error message here?
Everything is working! Thanks for the support!
Enjoy your day.
I get this message:
"This application has failed to start because its side-by-side configuration is incorrect. Please see the application event log or use the command line sxstrace.exe tool for more detail."
I don't know how!
I only want to click install, insert my license number and everthing else is taken care of!
Please help!
Hello Tersia,
AVG PC TuneUp
User-added image
Why dnt your try Keygetter.com, it will help you to recover your product key instantly
