Hello Richard,
We are sorry for the inconvenience caused. We will check and help you to resolve it. Please provide the following information in order to assist you better :
Hello Richard,
I have to reboot several times a day because I'm kicked off the internet. The only way to stay connect is to continually use the browser to do searches or use a program that keeps using the internet. The error I receive is "AVG tap adapter v3 adapter disabled (105)" and invalid configuration (106). I have worked with hp tech department, and they cannot solve the issue and because it lists AVG that it might have something to do with the ATG antivirus software I have installed. If anyone has a suggestion on how to fix this problem, I would be very appreciative.
