Hello Vanessa
If you have lost your Internet connection, then you can try these steps to fix
| AVG (https://support.avg.com/SupportArticleView?q=Internet&urlname=Restore-Internet-connectivity&l=en_US)
I installed AVG and now my wireless internet will not work. The internet works on another computer that does not have AVG installed. I did not have connection problems before I installed AVG. Any advice would be helpful.
Hello Vanessa
